o2 sensor bad but which one
Old Oct 8, 2008 | 01:44 PM
mikey2timez's Avatar
mikey2timez
Default o2 sensor bad but which one
my check engine light cam on bout a week ago and now i have a slight misfire at times that comes and goes had the code read it tells me it the bank 1 sensor 1 where is this located can any one help thanks
Old Oct 8, 2008 | 01:48 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Bank 1 should be the upstream sensor. If you have a misfire, there are other issues you need to check, such as a cracked valve seat, misrouted plug wires, or a clogged cat.
FWIW - O2 sensors should be changed every 50 - 65K miles.
Old Oct 8, 2008 | 06:12 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Replace the O2 sensor quick. Because if you don't already have a clogged cat , you will. After you replace it , run some Techron + through it for a couple tank fulls and you might get lucky.
Old Oct 8, 2008 | 09:22 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Running Techron will not cure a clogged cat.
Old Oct 9, 2008 | 04:49 AM
zman17's Avatar
zman17
I know that! But it will help clear out the carbon build up in the motor the bad O2 sensor has undoubtedly caused.And might get rid of the misfire.
