Brake issues
Old Oct 11, 2008 | 12:16 PM
grizzlyfarmer2's Avatar
grizzlyfarmer2
Default Brake issues
just changed out pads and rotors up front and the left side grabs a lot harder than the right under a lot of pressure but in regular stop and go is the same. any idea what is causeing this??
Old Oct 11, 2008 | 12:22 PM
ophidia's Avatar
ophidia
The first thing I would do is take off the new rotor on the left side and hose it (and the pads) down really well with brake cleaner. I've had that happen when I didn't get all the oil residue off of the new rotor, and cleaning them solved.
Old Oct 11, 2008 | 01:31 PM
EricCartman's Avatar
EricCartman
+1... but I wouldn't take everythign apart. I would pull the tires off, and spray everything while it is assembled. Less chance of getting more oil all over it.
Good Luck,
Cartman
Old Oct 11, 2008 | 02:24 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Let them break in a while if they are brand new, like suggested above take the wheels off and spray everything down .If either of those things doesn't work, try bleeding them again. But I bet it's just the oil residue on the rotor as stated above.
Old Oct 11, 2008 | 03:58 PM
tazman6789's Avatar
tazman6789
also while u had it apart did u grease up the slides in the caliper, and put a lil grease in the rubber boots?also did u clean any rust or gunk off the bolts befor u put them back in? if one of the sides are sticking that could cause it to be a bit more grabby than the other side
Old Oct 11, 2008 | 08:55 PM
grizzlyfarmer2
i cleaned everything up real good so ill give them some time to break in.
Old Oct 12, 2008 | 06:18 PM
grizzlyfarmer2
the pull has gone away thanks for the insights they just needed a little time to break in but i will let ya know if it comes back
