Wild Vents???
Old May 31, 2012 | 03:36 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
While we appreciate the info, resurrecting a four year old thread isn't really necessary....
This thread belongs in the FAQ section.
Old May 31, 2012 | 05:20 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I have to agree, if nothing more than for just the pics.
Old Apr 28, 2015 | 07:07 PM
dodgemike13's Avatar
dodgemike13
ok, my 4*4 don't work and my vents opens and closes more than it should, do those have a common point in common that I should check, since its all ran by vaccum???
Old Apr 28, 2015 | 07:40 PM
Everything draws vacuum from the same source. If you have a leak, some things won't work, and others will exhibit bizarre behavior.... so, need to poke around under the hood, make sure everything is hooked up first. (check and see if your plenum is blown too... as that constitutes are rather severe vacuum leak.)
