Check engine light on
Old Oct 14, 2008 | 07:58 PM
ep33510's Avatar
ep33510
Default Check engine light on
Goodevening,
I need some help from the Tech guys here in the forum. I had the check engine light pop on this week, once this happened the tranny has had weird shifting patterns depending on load. This is the only visable issue going on I can find, I borrowed a scanner to see what code was popping up PO720. I have had in the past year had to replace the speed sensor in the rear Diff but that time I had a Engine trouble light,ABS light and the speedo would only read after you reached above 20 mph. If I could get some input on this issue it would be greatly appreciated. Thank you for your time and effort!
Pat Collins
Huntersville,NC
2000 Dodge 1500 5.9L
