changing a fuel injector do you need to change all 8
Old Oct 16, 2008 | 08:09 AM
jakemary's Avatar
jakemary
Default changing a fuel injector do you need to change all 8
ok I have a 98 2500 4x4 auto. I have a misfire in cyl.# 1 . would you change just the #1 or change all 8? any after maket one out there to get or stay away from ?
accel super coil
fastman 52 mm
fastman 02 elemator
hollow cat.
glasspack.
k&n cold air intake.
thanks
Old Oct 16, 2008 | 08:45 AM
TXcharger07's Avatar
TXcharger07
are you sure its the injector? plugs can cause misses also or the distributor.
Old Oct 16, 2008 | 09:18 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Are you certain the inlet side of the injector isn't clogged or that it isn't a broken wire to the injector? Have you moved the injector to another cylinder to see if the misfire changes cylinders?
Either way, if the injector is truly at fault, they can be replaced individually. At ~$70 a pop, I don't think you'd want to replace all 8 at once! Also, when replacing injectors replace the O-rings. It's cheap insurance against an engine fire from a leaky O-ring.
Old Oct 17, 2008 | 07:17 AM
HankL's Avatar
HankL
I agree that all 16 o-rings should be new
and lubricated as the fuel rail is re-installed
I believe it is ok to change just one injector if it tests bad
it is my opinion that having the factory fuel injectors
tested and cleaned for about $20 per injector
is a a reasonable thing
and with the test results
I would put the two highest flowing injectors as measured on the test stand
in cylinders 7 and 8
... the ones at the back of the engine
A 'ColorTune' sparkplug is another way to diagnose at a problem cylinder
using its small window to look at the color of the flame inside that cylinder compared to others
http://www.northerntool.com/webapp/w...le&cm_ite=auto
Old Oct 17, 2008 | 08:36 PM
jakemary's Avatar
jakemary
so you have to pull the whole rail up all 8 come up not just one side bummer but ok. I have a new cap rotor , dizzy, accel coil the pcm says misfire cyl #1
