Coolant stench and no apparent leaks
Old Oct 16, 2008 | 01:18 PM
ophidia's Avatar
ophidia
Default Coolant stench and no apparent leaks
I seem to have developed a coolant stench under the hood of my truck (99 1500, 360). I can't see any coolant leaks anywhere, there doesn't seem to be any play in the water pump pully (with the belt on, anyway). I put a new radiator cap on it (16PSI) thinking that the old one was shot and burping too much making the stink. This made no difference.
There is no smell inside the cab so I don't think it's heater core related. Could the coolant bottle be making a strong smell?
Is there anything specific I can check?
Old Oct 16, 2008 | 02:27 PM
Viper37's Avatar
Viper37
You could have a pinhole leak in your coolant bottle, or even the radiator.
Another place the smell could be coming from, is a faulty seal where the transmission lines go into the radiator.
Old Oct 16, 2008 | 06:20 PM
dodgeman22's Avatar
dodgeman22
did u say with the belt on there is no play with the water pump then pop the belt off its an automatic tensioner, then wiggle it see if anything do u lose any water if so then you have a leak
Old Oct 16, 2008 | 06:48 PM
ophidia's Avatar
ophidia
I pulled off the belt, and there doesn't seem to be any play, nor does it lose coolant. Grrr...
If it were just the water pump it would be too effin' easy for this particular truck...
Old Oct 17, 2008 | 12:04 AM
dodgeman22's Avatar
dodgeman22
no idea, just wondererin how does your coolant look, and when was the last time it was changed
Old Oct 17, 2008 | 12:40 AM
Viper37's Avatar
Viper37
delete
