Autometer Transmission temp gauge problem.
Old Oct 16, 2008 | 09:39 PM
hometheaterman's Avatar
hometheaterman
Default Autometer Transmission temp gauge problem.
I got done installing my Autometer Transmission temperature gauge today. Well, yesterday but was still working on the paint for the pod today so just had it hanging there yesterday although it worked. Then today I put it in the pod and thought all was good. I went riding in it tonight and all was great for the first 5 miles or maybe even 10. About time it got up to temperature I noticed it shot up to 250 degrees which is as far as it can go. Well, a little past 250. At first I thought it had over heated or something although I thought that was odd. I started pulling over to check it. Everything I can see was hooked up just fine. If you hit the gas hard it would go back down to right around 150 where it should be and was before it messed up. If you slam the door it will also go down to around 150. That kind of made me think it was the gauge but if you disconnect the sending unit wire it goes back down to 100 which is the lowest it can go. If it was the gauge would it still do that? If you get on the gas hard it will go back down then it will start going crazy all over the place then back up to as far forward as it can go. Any idea's? Is there anything I could have wired wrong that would cause this? I'm positive it's wired up right just wondering if something could have happened to one of the wires causing this or does it sound like a faulty gauge or faulty sending unit or what? I thought it was odd it worked great for a bit before doing this.
Old Oct 16, 2008 | 11:30 PM
Rex-TheDOGG's Avatar
Rex-TheDOGG
Where is your ground wire connected?
Old Oct 17, 2008 | 12:16 AM
hometheaterman
Grounded it to the cross member under the transmission. The instructions said to ground it near the sending unit so I ran a wire down there with the power wire to ground it nearby.
Old Oct 17, 2008 | 12:40 AM
Silver_Dodge's Avatar
Silver_Dodge
Mine did something like that when I first installed it. I rewired it so that it had it's own dedicated power wire, and it went away. Then, when I moved the gauge to the pod it is currently in, I tried sharing the power with another gauge, and it did it again. Only seemed happy when it had it's own dedicated power wire. Try that maybe.
Old Oct 17, 2008 | 12:44 AM
Viper37's Avatar
Viper37
Just out of curiosity, where is the sender plugged in? Did you drill a hole in the pan or did you use the drain plug?
Old Oct 17, 2008 | 01:04 AM
hometheaterman
Does it really need to be switched power or did you wire it directly to the battery for a constant power?
Old Oct 17, 2008 | 01:05 AM
hometheaterman
The sending unit is in the front servo port for right now at least.
Old Oct 17, 2008 | 01:31 AM
Viper37's Avatar
Viper37
When you installed it did any fluid get into the back of the sender?
Old Oct 17, 2008 | 07:45 AM
Silver_Dodge
I prefer switched power.
Old Oct 17, 2008 | 10:46 AM
hometheaterman
So where did you wire it to that isn't shared with something else?
