ball joint tools needed?
remember to put the ball joints in the freezer before installing them, the cold shrinks them and makes them easier to install.
I didnt use a press on mine, just a C-clamp, some sockets (used as spacers) and when they got in far enough, I used a hammer to finish the job. I.E. piece of steel ontop of the spacer and nice even hits.
ball joints suck
ball joints suck
ball joints suck
ball joints suck
Just did mine yesterday. If you have a parts store nearby just rent their c-clamp press and the adapter kit for 4wd vehicles. Its not that hard with the right tools. Here is a little writeup that helped me figure out how to use the press.
http://www.pavementsucks.com/tech/balljoint.php
It really was pretty easy. Not sure why everyone hates doing them, following the advice in that article I had no problems. The only deviation was not using a pickle fork to separate the knuckle from the factory ball joints, I just used a small 3lb sledge and gave it a couple whacks around the joint until it popped loose (similar to how I remove a tie rod end). Hope this helps.
