????? about gears and rpms
Old Oct 25, 2008 | 08:21 PM
pcfixerpro's Avatar
pcfixerpro
Originally Posted by 01DodgeRam360
Yes. I have reset the computer several times. What I have found is that my mileage is quite a bit better when I can stay in overdrive such as backroads and the highway. But city driving is ultimately the same. With the 35" tires, I flirted with 10-11. Now I flirt with about 11-12.5. It did give me about a mpg differance, but I was suprised how similiar my truck is still. Still drives pretty the same, just without the noise of a mud tire. Goes to show these rams don't let much phase them. I'm still only getting about 240 miles to a full tank of a fuel though.
The thing is.... your tire size is programmed into the computer to give you accurate speedo readings. Reseting the computer doesn't change this setting. If its programmed for 265/75/16 or what ever came stock, going with a 285/75/16 means that your not recording as many miles as you are covering (your recording less). that means your mpg (I assume your going off the computer generated) is not being accurately given. Not to mention its not that accurate to being with, but the small difference that did show is actually bigger than its telling you because it assumes your running as smaller tire.
Old Oct 25, 2008 | 08:45 PM
01DodgeRam1500's Avatar
01DodgeRam1500
so i did a check and i actually have 225 75 r16s
Old Oct 26, 2008 | 12:46 AM
05DodgeRamHemi's Avatar
05DodgeRamHemi
I have figure it has to be pretty accurate though. My truck stock comes off the lot with 275/70/17 tires. So a 285/70/17 shouldn't be making much of a difference, right? 4.10 gearing with 285 tires is pretty much a dead on combo. Even said, I'm averaging 11.5mpg....which to me, sucks. This is why I plan to raise this truck up and put big tires back on it again. I say this because my gas mileage sucks still even with 285s, so I might as well be enjoying the look of huge tires while I'm getting ****ty gas mileage. I will only get big tires though, IF, I get an APS...
Old Oct 26, 2008 | 07:20 AM
pcfixerpro's Avatar
pcfixerpro
Yea there isnt that much difference to worry about. It slipped my mind that you do have the offroad for a sec lol. Just forget I mentioned anything until you throw those 35's back on. I know for me to throw on 285's, it throws the speedo off 6mph at some point. And for me if I don't recalibrate the computer for the new tire size, the computer wouldn't see about 7.32 miles-ish for every 100 that I put on when calculating off my current tire, and a 285 of the same brand.
Old Oct 26, 2008 | 11:31 PM
05DodgeRamHemi
This is why I suggest gearing. In his case, he has 3.55 gearing. I wouldn't waste my money going to a 3.93. I'd spend the money on 4.10s. Then you'll notice something.
Old Oct 27, 2008 | 12:58 AM
talon6's Avatar
talon6
i have the 3.93's and wish mine was a little lower. 4.10. or 4.56 if you donnt do a lot of interstate driving.
