engine compatibility
Old Oct 28, 2008 | 08:33 PM
dakotas ram's Avatar
dakotas ram
Default engine compatibility
went through some water today with my CAI and sucked water into engine......not sure what kind of damage yet, but it wont budge a bit with plugs out..........if i decide that this one is scrap....what all engines would be a pretty much straight swap? what about OBDII? v6?
Old Oct 28, 2008 | 09:11 PM
dakotas ram
did some more searchin so v6 is off the list.....all i need to go to a 5.9 is the damper and flywheel?......still didnt find a good answer for going to a OBDII engine, will swapping intake take care of all of that?
Old Oct 28, 2008 | 09:27 PM
pcfixerpro's Avatar
pcfixerpro
Just swap in what you had. Otherwise add a computer to the list too. Also I think the injectors may be different on the 5.9 Also remember you have egr.
Old Oct 28, 2008 | 09:40 PM
dakotas ram
would my old intake not take care of the egr and injectors? what about a newer 5.2?
Old Oct 28, 2008 | 09:59 PM
pcfixerpro's Avatar
pcfixerpro
a newer 5.2 will prb work without a problem, but you will need to reuse your intake. Perfect time to fix your plenum gasket if you haven't already. You might also need to swap over your exhaust manifolds for the egr. Other than that, I think the 5.2 option is the easiest.
Old Oct 28, 2008 | 10:18 PM
dakotas ram
what would make the 5.9 so hard? doesnt the intake and exhaust swap? motor mounts too, right?.....i'm not set on one, just if i find one or not..
Old Oct 28, 2008 | 10:22 PM
dodgeram07's Avatar
dodgeram07
wow.. how much water? were you boating or what? how did it happen?
Old Oct 28, 2008 | 10:45 PM
pcfixerpro's Avatar
pcfixerpro
I dont remember about the motor mounts. But if you swap a 5.9, now you need the engine, you need the computer, the balancer & flywheel (should be on a junkyard motor), injectors etc. I haven't done a swap so i could be missing something, but last time i looked it up thats what I came across. The intake bolts up, and the exhaust should swap.
Old Oct 28, 2008 | 11:25 PM
dakotas ram
check out my other thread, it shows the cold air intake.......the filter is right in front of the grille opening and i was out goofin off in the bottoms and i splashed through a big puddle and it died coming out.....thats when i actually thought about the CAI.....i figured it just got wet and my engine died...but then when i tried to start it, my starter just clicked, so i went and got one and put it on and the same click.....my fatherinlaw had me take the plugs out to see if my engine was locked up and sure enough it was....the plugs were wet and from what i can tell from dipping a stick in one of the holes...theres about 1/4" of water on top of the pistons.....stupid me.......
Old Oct 28, 2008 | 11:34 PM
dakotas ram
so if i got a newer 5.9, would i need an older computer?
