weird pinging issues...need help.
Old Jan 26, 2009 | 08:56 AM
  #241
steve05ram360's Avatar
steve05ram360
I would call whoever made the tune that you have (you said it is modified) and find out what they recommend (or call someone like KRC Performance). in that link I posted I though it indicated 2-6?? for a stock block setup, 6-8 for modded block. one way to look at the fuel sync is it is similar in a way to ignition timing... there is settings that will make it run & then there should be a sweet spot for optimizing performance
Old Jan 26, 2009 | 01:40 PM
  #242
lv360ram's Avatar
lv360ram
aim4squirrels, dude, you need to buy a scanner.
I had a few problems with my Dakota and decided to spend the money to get an OBD 1 scanner that allowed me to monitor everything realtime. After I fixed the problems years ago I haven't needed it since. It's been sitting in my garage for years collecting dust, It's kinda like having insurance.
You know, Murphy's Law
Old Feb 6, 2009 | 04:56 PM
  #243
aim4squirrels's Avatar
aim4squirrels
Guess I didn't clarify as I still have several ask randomly,
The ping was fixed after the retune and me tearing in and cleaning the injectors, soldering IAT, replacing the coolant temp sensor, etc.
I do get a random misfire code after installing the fresh tune but after the PCM figures everything out, it goes away and doesn't come back.
I have my suspicions that the heads might be cracked and I'm going to replace them with some heads with 2.02 intake valves. It should compliment the new intake nicely. Got a good deal a pair of EQ Iron Rams with the 2.02 intake valves for under $800.00. Install will be March if I can scrape up the cash.
Old Feb 6, 2009 | 05:16 PM
  #244
dodgeram07's Avatar
dodgeram07
of boy new heads!!!!!!!!!!!!!!!!!!!!! now we are make sum ponys
Old Feb 15, 2009 | 06:48 PM
  #245
aim4squirrels
Heads are on their way.
EQ Iron Rams 2.02 intake valves 1.62 exhaust. Hardened, pressed in exhaust valve seats. Supposedly a different and better casting than the stockers.
I'll have to call Dan Arcand and see if I should be upgrading to the 52mm TB. The madness never ends...
Old Feb 15, 2009 | 07:35 PM
  #246
wjxavier's Avatar
wjxavier
i've realized that myself. after i installed my CAI, it just keeps getting bigger and bigger. now i just want to upgrade more and more lol
Old Feb 15, 2009 | 08:25 PM
  #247
Rex-TheDOGG's Avatar
Rex-TheDOGG
Did you decide to get the go-stick or stay with the stock grind?
Old Feb 15, 2009 | 08:34 PM
  #248
PurplDodge's Avatar
PurplDodge
Its a disease!!
Old Feb 15, 2009 | 09:02 PM
  #249
wjxavier's Avatar
wjxavier
it is a disease, one that unfortunately my wife doesn't enjoy lol
Old Feb 15, 2009 | 09:11 PM
  #250
aim4squirrels
the stick will have to wait for the summer, the stocker stays for now. Can't afford the heads, stick, and new roller rockers right now. Might need new lifters at 90K and wouldn't mind hardened pushrods either.
