Speedometer not working
Old Nov 1, 2008 | 02:13 PM
justinB's Avatar
justinB
Default Speedometer not working
I just bought a used 97 Ram 2wd v6 and the speedometer doesnt work. I replaced the speed sensor in the axle and that didnt help. The needle on the speedometer isnt broken, and there is no sensor on the transmission. Any ideas? Thanks.
Old Nov 1, 2008 | 02:54 PM
magicc8ball's Avatar
magicc8ball
yea i have the same issue, so what i have done is i took out the cluster and took out the speedometer gauge and saw some cracks in the solder joints so i resoldered it got it all hooked up again, just cant test it yet cause my trans kickdown cable is broken.
none of your other gauges have any problems right?
Old Nov 1, 2008 | 03:49 PM
justinB's Avatar
justinB
all the other gauges work fine. Is there an additional speed sensor that i dont know about?
Old Nov 1, 2008 | 04:18 PM
magicc8ball
one on the tranny and then one on the rear diff. but i dont know if that is going to be your prob. the speed sensors send readings to other things not just the speedometer. so if your speedometer is the only thing screwing up then id pull the cluster and pull the speedometer out and check the solder joints on the back. takes about 30 mins
