Bleeding rear brakes
Old Nov 1, 2008 | 04:28 PM
big96ram's Avatar
big96ram
Default Bleeding rear brakes
hey guys i had a brake line split on me the other day and i was wondering how to get the rear brakes to bleed? this is my first time owning a dodge so any help would be appreciated
Old Nov 1, 2008 | 04:49 PM
dhvaughan's Avatar
dhvaughan
replace the brake line.
fill up master cylinder.
locate bleeder screw on rear wheel cyl's.
spray with wd40
use a good fitting socket and break them loose, then retighten with small wrench, not too tight.
find a piece of hose or vac line about 1/4 dia and 18" long and a small bucket.
you'll place this over the bleeder to catch fluid and reduce mess.
get an assistant to operate the brake pedal.
pump up the brake pedal 2-3-4 times and hold it. say 'pedal up'.
you release bleeder screw. air/fluid comes out, hopefully in the bucket.
pedal operator says 'pedal down' and holds pedal down.
you tighten bleeder and say 'ok'.
repeat several times, until all fluid comes out, and pedal gets good and tight.
start w/right rear, then left rear.
don't let master cyl run out or you have to start over. refill as needed.
its a good idea to flush out all the old dirty brake fluid, front and rear.
front caliper has the same bleeder.
if ithe bleeder breaks off, you'll probably have to replace wheel cyl or caliper, so be careful and break them loose gently and don't round them off.
Old Nov 2, 2008 | 12:04 AM
Jr. Mechanic's Avatar
Jr. Mechanic
Just to add to the above reply, on top of starting over if you empty the master cylinder, you may also have to bench bleed it.
Old Nov 2, 2008 | 06:21 AM
zman17's Avatar
zman17
Retired Moderator - RIP
The shoes should also be adjusted properly before bleeding.
Old Nov 2, 2008 | 08:11 AM
White Ram's Avatar
White Ram
Look into "Speed Bleeders". Very inexpensive.
Had them on my Cherokee. Makes the whole process a lot easier.
Old Nov 2, 2008 | 11:59 AM
big96ram's Avatar
big96ram
well i took it to my uncles and we put it up on the hoist and used a bleeder through the compressor got alot of stuff out but im still having the same problem with it. no rear brakes and no abs.
