still poping
sorry I have not got back sooner. I tighten. Up my wheel bear nut and it went away for a day or it didn't happen for a day, but then today it poped again, i need to cheack the wheel bearing again, do you guys think the bearing nut is backing off?
I think you need to replace the front wheel bearings. At least the ones on that side.
****update*****
ok guys i took the truck over to work last sunday to use the shop and it turned out to be the outer tie rod,,, i i replaced both.. so far no more poping..
just thought i would they you guys know
