Bleeding the master cylinder?
Old Nov 6, 2008 | 02:58 PM
thunderz's Avatar
thunderz
Default Bleeding the master cylinder?
I just replaced my rotors, pads, drums, shoes and rear wheel cylinders and I need to bleed the system. I tried searching for an answer before posting this question as well.
Do you need to bleed the master cylinder on a 99' 1500 4x4? I dont even see bleeder screws on it. I ask this because a lot of older cars I have had needed the master bled whenever the brakes needed bleeding.
Old Nov 6, 2008 | 03:09 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Shouldn't. Remove the lid and bleed as usual while keeping the reservoir topped at all times.
Old Nov 6, 2008 | 05:33 PM
zman17's Avatar
zman17
Retired Moderator - RIP
If you got it completely empty while you were doing the other work you might want to bleed it.
