plenum torque and bolt grade?
Old Nov 10, 2008 | 12:53 PM
dakotas ram's Avatar
dakotas ram
Default plenum torque and bolt grade?
what is the torque and sequence for the plenum and are grade 5 bolts good enough for the plenum, intake, heads?
Old Nov 10, 2008 | 01:09 PM
Silver_Dodge's Avatar
Silver_Dodge
http://dodgeram.info/tsb/2000/09-05-00.htm
Old Nov 11, 2008 | 12:58 AM
dakotas ram
ok, so i guess grade 5 will be fine, ayone know about the others?
Old Nov 11, 2008 | 03:32 AM
bigster's Avatar
bigster
maybe better to buy a new set of bolts, just to be sure that the grades are correct and the lengths are right. I'll check this afternoon for the right torque and sequence (my book is in my workshop ).
Greetz,
Biggie
Old Nov 11, 2008 | 06:41 AM
HankL's Avatar
HankL
there have been some past posts that the 'root' of the plenum gasket problem started many years ago when the holes on the intake manifold side somehow did not get tapped deep enough.
it might pay to check each threaded hole,
and perhaps use a 'bottoming tap' in each one
to ensure adequate thread depth
Old Nov 14, 2008 | 11:58 AM
bigster's Avatar
bigster
Hey, sorry for the delay, forgot my book again last time
Apparently there's no sequence to follow, just torque steps:
Step 1: 24 in-lbs
Step 2: 48 in-lbs
Step 3: 84 in-lbs
Have fun!
Greetz,
Bigster
Old Nov 14, 2008 | 12:19 PM
dakotas ram
thanks
