stuck in reverse HELP
Old Nov 11, 2008 | 02:40 AM
Rusty Staples's Avatar
Rusty Staples
Default stuck in reverse HELP
i own A 2001 RAM off road 1500 4x4 with 5.2l mag and 5 speed , i was backing out of a parking stall and then stuck the shifter in to what should be 1st and nothing happened so i ran the shifter through the gears only to find i had reverse in where fifth should be and also the normal reverse position and no forward gears . if i try to use the gears 1st through 4th the truck just lugs down, anybody with any ideas as to how to fix this i need to know asap thanks ?( tranny is a nv 3500 i believe...)
