Headlight switch culprit for no low beams?
Old Nov 22, 2008 | 10:11 PM
smuhhh's Avatar
smuhhh
Default Headlight switch culprit for no low beams?
I have no low beams. I have check and rechecked fuses. I am not getting power before the lights, so it is not the bulbs. I read that 2nd gen rams do not have a relay for the headlights, I have also read that the headlight switches aren't the best. Is it possible that a fualty headlight switch could be causing my truck's low beams not to work? Daytime/turn signals/highbeams are working correctly. Thank you.
Old Nov 22, 2008 | 10:45 PM
dhvaughan's Avatar
dhvaughan
well i'm sitting in my recliner and its too cold and dark to go out and look in the pdc, but i think my 01 does have relays for the headlights. look in your pdc box beside the battery.
i wouldn't think its the on/off switch if you have high beams but no low beams. on/off does just that, on vs off, and since you have highs, the switch is working.
the multifunction sw on the column is the hi/low switch. check for power at the relays, and if none, back track to the multifunction sw. surprisingly, these are not expensive. i replaced mine w/one from autozone for $42.
Old Nov 22, 2008 | 10:55 PM
smuhhh's Avatar
smuhhh
Checked the pdc, no relay there for headlights. I think that the 2001 might have a different set up for headlights. I have a pull **** which controls lowbeams (one pull) high beams (two) and interior lights (twist). So it is more than an off/on.
Old Nov 22, 2008 | 11:11 PM
dhvaughan's Avatar
dhvaughan
oh. what year is it.
remove the switch and test it for voltage on all settings.
so when your driving down the road and want to switch from dim to bright - you're saying you have to reach over to the headlight switch on the dash ?
Old Nov 22, 2008 | 11:16 PM
smuhhh's Avatar
smuhhh
It is a 97. That is correct, the only headlight control is one ****. Very basic. The only **** coming out of the steering column is for the turn signals/wipers.
Old Nov 23, 2008 | 03:14 AM
Viper37's Avatar
Viper37
Why did you make a new thread for this? You already have a thread going on this topic.
Old Nov 23, 2008 | 08:58 AM
charlie1935's Avatar
charlie1935
That lever is also your dimmer switch.
Old Nov 23, 2008 | 10:30 AM
smuhhh's Avatar
smuhhh
Three reasons
1. It's a different subject
2. the other thread seams to be dead
3. why do you care? I can't beleive you took the time to post that.
Yes that lever is also your dimmer switch.
Old Nov 23, 2008 | 12:26 PM
Viper37's Avatar
Viper37
Three reasons
1. No its not.
2. Why are people still replying to it then?
Honesty, there is NOTHING we can do to help you at this point. banging on your keyboard isn't going to fix your truck.
Old Nov 23, 2008 | 01:54 PM
Satellite's Avatar
Satellite
One pull of the **** should be parking lights and tail lights. Two pulls should be headlights (both low beam and high beam). Pulling the turn signal stalk toward you will switch between high beams and low beams.
