water pump
Old Nov 26, 2008 | 01:12 AM
TXcharger07's Avatar
TXcharger07
got it all back together tonight and its to late and i'm to scared to start it haha i will get her going tomorrow morning though... anticipating it leaking... grr
Old Nov 26, 2008 | 04:52 AM
talon6's Avatar
talon6
clutch fan is a real pita to get off. i feel your pain.been there done that. i changed to the e-fan setup. cut a 2x4 and wedged it in there, and had to walk away once.didnt think i was going to get it off.
did you do the 180 stat?
Old Nov 26, 2008 | 10:22 AM
TXcharger07
ya i got the thermostat... it just looks like a bitch to get in so i'm not gonna mess with it. lol i've got the receipt so i will probably take it back.
i'm gonna look at it again when i go down to crank it up in a minute.
Old Nov 26, 2008 | 05:14 PM
dodgeman22's Avatar
dodgeman22
to remove that fan clutch just take the correct wrench and smack it with a hammer several times and it will break free
Old Nov 27, 2008 | 12:28 PM
lv360ram's Avatar
lv360ram
I've removed 3 Magnum engine fan clutches and didn't have any problem.
Old Nov 27, 2008 | 09:36 PM
TXcharger07
It's not a problem when you have a impact hammer haha
turns out i need a new heater hose... at least the part that goes into the pump... turns out i damaged it when i yanked it out of the old one. I can't get it to seal properly, at least the water pump is on there really good now.
had to use some KY to get the upper inlet hose onto the pump lol
Old Nov 28, 2008 | 01:28 AM
bigsquat's Avatar
bigsquat
i was told by a mechanic that if you change your water pump you should also change the fan clutch at the same time. I dont know if he was right or not, just thought i would throw his 2 cents in.
Old Nov 28, 2008 | 01:40 PM
talon6's Avatar
talon6
i have seen many posts on clutch fan removal,and this is the first time i have seen someone say it was easy. you must be a hulk,or super lucky.
Old Nov 28, 2008 | 01:43 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Or he has the right tools like I do. :-)
Old Nov 28, 2008 | 01:47 PM
talon6's Avatar
talon6
yeh your right, the right tools do make a difference on any job.
