water pump
Old Nov 23, 2008 | 03:36 PM
TXcharger07's Avatar
TXcharger07
Default water pump
went bad i think, it's leaking out of the top corner of it.
ideas?
is the $110 for the "high performance" pump worth it?
http://store.summitracing.com/partde...rsview=sku&Ns=
Old Nov 23, 2008 | 03:42 PM
dodgeram07's Avatar
dodgeram07
from summit
"Increase pump pressure up to 300 percent"
* Eliminate steam pockets trapped inside the engine block
* Reduce engine temperature by 15-30 degrees
* Help increase horsepower
Increase pump pressure up to 300 percent= may blow out sumthing
Reduce engine temperature by 15-30 degrees =throw a code
i wouldn't buy it..
Old Nov 23, 2008 | 03:45 PM
TXcharger07
Originally Posted by dodgeram07
from summit
i wouldn't buy it..
that's what i was thinking. but, what about replacing the thermostat at the same time? would i have problems with a OE replacement water pump and a 180* thermostat?
Old Nov 23, 2008 | 05:31 PM
working4ev's Avatar
working4ev
Thing with running the 180 thermostat you will throw a code (engine temp lower then spec).
any one know how to trick the ECU to thinking it is the right temp???
Old Nov 23, 2008 | 05:56 PM
TXcharger07
o ok!
the stock temp is like a 195* right?
Old Nov 23, 2008 | 07:43 PM
dodgeram07's Avatar
dodgeram07
Originally Posted by TXcharger07
o ok!
yes stock is 195.....
there are a few people on the forum running 180 with no code/ and some get a code.
so you may get luck, you may not get lucky with a 180
Old Nov 23, 2008 | 08:18 PM
TXcharger07
well... i'd rather not chance it... if they are the same price i may say screw it haha
Old Nov 23, 2008 | 08:44 PM
charlie1935's Avatar
charlie1935
I've run a 180 thermostat for four years with no code.
Old Nov 24, 2008 | 12:36 AM
talon6's Avatar
talon6
no code with my 180.i tried a 165 (i think that was the temp) and threw a code.
Old Nov 25, 2008 | 12:47 AM
TXcharger07
ok so... i hate my clutch fan!!!! we could not get it off to save obama's life!
but... i can take it to work tomorrow and use the right tool haha got the new pump on... had to take off the radiator and shroud and everything to get to it though. went on ok... came off like a bitch haha
but this was all combined with me not knowing what the hell i was doing but reading a book haha
tomorrow just gotta get the fan put on and tight and put the shroud on. Then fill the radiator and hope to god there isn't a leak!!!
this whole thing sucked cause i wanted to get my headers on this week...
