swapped engine 318 now 360?
Old Nov 24, 2008 | 11:00 PM
seamorin@yahoo.com's Avatar
seamorin@yahoo.com
Default swapped engine 318 now 360?
is this even going to work on a 99 ram with the 318 computer?
my cousin already swapped engines and truck won't run properly
He said some guy told him it would work, I have no idea and really
need some strong advice on this situation.
Do I just drop the distributor and let the computer take over?
Old Nov 25, 2008 | 09:58 AM
Ram2K1's Avatar
Ram2K1
I really don't see how you could run a 360 with a 318 pcm. I may be wrong on this, but I believe you are going to end up having to get a pcm for a 360. Anyone else?
Old Nov 25, 2008 | 10:27 AM
talon6's Avatar
talon6
yeh,you will need the pcm too.
Old Nov 25, 2008 | 11:31 AM
charlie1935's Avatar
charlie1935
There is a procedure for setting the distributor, it's best to find a garage with the proper scan tool to set it. It controls the injectors, not the ignition timing.
Old Nov 25, 2008 | 08:54 PM
seamorin@yahoo.com
Will the 360 pcm plug to the factory wiring harness of a 318?
Old Nov 25, 2008 | 10:10 PM
jasonw's Avatar
jasonw
Site Moderator
I think so. Make sure they are of the same model year.
Old Nov 26, 2008 | 02:33 AM
acsamples79's Avatar
acsamples79
+1 i was told awhile back, it would work as long as the model and year were the same
