gurgling noise in passenger side
Old Nov 26, 2008 | 01:29 AM
dodgeforlife15's Avatar
dodgeforlife15
Default gurgling noise in passenger side
got a weird noise coming from the passenger side under the dash. it's a gurgling noise that happens when i start the truck and when i step on the gas for about the first 5 minutes after i start the truck. what could possibly making that noise?
Old Nov 26, 2008 | 01:33 AM
vmann's Avatar
vmann
happens to me too. pretty sure its normal. usually its just a little hick up at the start
Old Nov 26, 2008 | 04:37 AM
talon6's Avatar
talon6
antifreeze circulating through the heater core.
Old Nov 26, 2008 | 07:27 AM
dhvaughan's Avatar
dhvaughan
air in the cooling system.
air collects in the heater core because that's the high spot. its normal to have some air after a coolant refill or flush, but it should work itself out after a few days. if not, then you're leaking coolant and sucking air somewhere...
Old Nov 26, 2008 | 08:27 AM
charlie1935's Avatar
charlie1935
A common problem. I jacked the front end up as high as my 3 ton jack would go, removed radiator cap, warmed engine up and squeezed top radiator hose until no mare air came out. Put rad. cap on, no more gurgle. Same thing can be done by parking headed up hill.
Old Nov 26, 2008 | 11:42 AM
vmann's Avatar
vmann
guess ill go find a hill then
Old Nov 26, 2008 | 01:01 PM
dodgeforlife15
Then I am off to find a hill as well. Thanks guys.
Old Nov 26, 2008 | 04:19 PM
aim4squirrels's Avatar
aim4squirrels
just put the passenger wheel up on a curb. no need to go searching for the perfect hill.
Old Nov 26, 2008 | 04:22 PM
ophidia's Avatar
ophidia
Or drive it up on ramps.
Old Nov 26, 2008 | 05:09 PM
Redneck2345's Avatar
Redneck2345
or up a tree
I just had to add to mine, the gurgle went away
