Freeze plugs thread on or press fit????
Old Nov 27, 2008 | 08:22 AM
Obiejuankinobie's Avatar
Obiejuankinobie
Default Freeze plugs thread on or press fit????
I have a friend who purchased freeze plugs for his Chevy only to find they thread in. He wants to sell them but first I must ask are they applicable to my truck and are the diameters the same?
Old Nov 27, 2008 | 08:43 AM
aim4squirrels's Avatar
aim4squirrels
The Ram's are press in, I just had one sitting around here. Dang it! can't find it to measure it.
Old Nov 28, 2008 | 04:19 PM
dhvaughan's Avatar
dhvaughan
all freeze plugs are press in. that way they in the event of a coolant freeze, they can push out to release pressure. if they were threaded, then they wouldn't do any good.
Old Nov 28, 2008 | 04:23 PM
aim4squirrels
maybe he's referring to the bolts in the block next to the freeze plugs then....
Old Dec 2, 2008 | 08:48 AM
APA228's Avatar
APA228
The "threaded" type could be the universal replacement type used for a damaged hole or in a hard to reach location like near a starter. They are made with a captive nut/washer and bolt that squeezes a rubber center section.
Old Dec 2, 2008 | 09:02 AM
charlie1935's Avatar
charlie1935
Some race engine builders use pipe plugs instesd of the original welch plug. Some also use brass instead of steel.
Old Dec 2, 2008 | 09:49 PM
dhvaughan's Avatar
dhvaughan
what happens if the engine freezes up ?
Old Dec 2, 2008 | 10:13 PM
PurplDodge's Avatar
PurplDodge
Im pretty sure not a lot of race engines will see cold weather.
Old Dec 2, 2008 | 11:03 PM
Mike Roma's Avatar
Mike Roma
The "proper" term is "core plug". They are needed because of the sand casting method used manufacturing the block.
A few blocks do use threaded plugs. Some performance blocks have threaded plugs for "strength and security". Brass is used in marine applications.
Old Dec 5, 2008 | 08:16 PM
charlie1935
If it gets cold enough it's going crack the block any way, freeze plugs wont save it.
