who turned the lights out?
Subscribe
Dec 1, 2008 | 01:28 PM
Its just an Isolation point.
Reply 0
Dec 1, 2008 | 01:32 PM
well i just tried it. and holy crap. it worked. the other two that have them are the two airbag fuses. i checked those too. and they are fine. but it all works now. thanks
Reply 0
Dec 1, 2008 | 01:56 PM
Fusible link
might be a fusible link on the initial wiring... if so they are usually located in the first 12" from the positive battery connector. Use a simple volt meter or better yet dust off that voltage probe and see which one is receiving voltage. Then re bridge wire until a replacement falls into plan. Fusible links are used to burn out before your wiring harness catches your truck on fire. Kinda like what a breaker does without the handy switch.
Reply 0
Dec 18, 2008 | 01:14 PM
Glad i could help.
Reply 0
Subscribe
