factory installs
Old Nov 29, 2008 | 10:44 PM
encorejc35's Avatar
encorejc35
Default factory installs
hey guys, just got a new truck and wondering a couple questions about it, it is a 95 ram, 2500, 4x4, 8800 gvw, do i have dana 60s on both front and back?, what are their normal gear ratios? what tranny did mine come with? lastly, about how long does it take to replace a plenum gasket and whats a good way to find out if its leaking? im losing oil from somewhere on the top of the motor, thanks alot
Old Nov 29, 2008 | 10:51 PM
meanwhitemopar's Avatar
meanwhitemopar
well i know on my truck on the under side of the hood, like right by the dodge emblem but on the inside if that makes sence, has a sticker. it will tell you what axles you have, what trans you have and the first two didgets of the gears.. like mine says 3.5, i can put it together and know my truck has the 3.55 gears, but that gasket. i have no idea
Old Nov 30, 2008 | 12:31 AM
BlueBeast2's Avatar
BlueBeast2
to see if you need to replace the gasket. remove the air box, open the throttle body flaps and look down into the intake. If theres pools of oil in there the gasket is shot. If thats all your doing it shouldn't take long. Get a huges plenum pan kit and some new intake bolts. You have to remove the accesory brackets pull the intake off and have at the new gasket and throw it back together. I would say a day or 2 for your first time. If you look at the DIY thread theres a full write up
