Brake Light Question
Old Nov 30, 2008 | 12:12 PM
Miguel's Avatar
Miguel
Default Brake Light Question
Ok guys my left brake light doesn't work, but the right does. We've changed the fuse and the bulb for the left brake light and it still doesn't light up. Any other suggestions the problem might be?
Thanks
Old Nov 30, 2008 | 12:35 PM
dhvaughan's Avatar
dhvaughan
use a voltage tester of some kind. probe the wire at the socket and see if you're getting power. for one man testing, you can turn the blinkers on. blinker light and brake light share a common circuit. if you've got power, check the socket for corrosion or junk, maybe spray out w/wd40. if no power, get the wiring diagram out of the 01 service manual in the merry christmas diy at the top. inspect/test wiring for problems. especially check for where previous owner may have snagged wires or put in a trailer connector.
Old Nov 30, 2008 | 12:40 PM
Miguel's Avatar
Miguel
oh yeah forgot to mention it was previously connected to a trailer, so your saying its a wiring problem?
Old Nov 30, 2008 | 12:45 PM
dhvaughan's Avatar
dhvaughan
probably. follow the trailer connector wiring back to where its spliced in. you'll likely find your problem there.
Old Nov 30, 2008 | 12:56 PM
talon6's Avatar
talon6
i had issues with my tail light circuit boards. they werent coroded or anything. replaced them both and problem solved.like 20bucks each from the dealer. one of the very few times i have bought parts from a dealer.
Old Nov 30, 2008 | 01:32 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The 2nd gens don't have a circuit board. IIRC
Old Nov 30, 2008 | 04:51 PM
eaglestorm's Avatar
eaglestorm
I would ck your trailer wiring esp if its aftermarket. disconnect the trailer wiring and see if you have power to the light. the aftermarket setup fail a lot . When I get one in for rear light problems and it has aftermarke wiring the first thing I do after cking the fuse is disconnect it most times everything is fine after that
Old Dec 1, 2008 | 02:18 AM
talon6's Avatar
talon6
never relized they didnt have boards. i have 3rd gen truck 2nd gen power.
Old Dec 1, 2008 | 08:26 AM
Miguel's Avatar
Miguel
Thanks for the feedback guys, problem solved
Old Dec 1, 2008 | 08:45 AM
devile's Avatar
devile
What was the problem???
