oil pressure
Old Dec 1, 2008 | 11:44 AM
dodge15004x45.9's Avatar
dodge15004x45.9
Default oil pressure
my oil pressurewhen i start my truck is over 40 i would say 50 or so and when my truck is warmed up it goes below 40 like 37 is this normal???
Old Dec 1, 2008 | 11:46 AM
Rex-TheDOGG's Avatar
Rex-TheDOGG
Mine does the same thing. I'm running Pennzoil 10W-30.
Old Dec 1, 2008 | 12:17 PM
dodge15004x45.9
i have mobile one and soon to be amsoil
Old Dec 1, 2008 | 03:29 PM
charlie1935's Avatar
charlie1935
Nothing wrong with that. Oil is thinner when it's hot.
Old Dec 1, 2008 | 03:48 PM
dodge15004x45.9
Default oil
ok thats fine but tell my why when my tuck is harmed up the oil pressure will go back down and as soon as i touch that gas it goes right back up.
Old Dec 1, 2008 | 03:58 PM
Rex-TheDOGG
The oil pump is like any hydraulic pump. Pressure and volume will increase with speed.
Edit: Make that pressure and flow rate, unless you have a variable-volume pump.
Old Dec 1, 2008 | 08:37 PM
dhvaughan's Avatar
dhvaughan
that's all normal. mine does the same thing.
Old Dec 2, 2008 | 04:31 PM
ibkg's Avatar
ibkg
Glad to see I'm not the only person who's truck does this too I got a 98' 3500 5.9 when its cold 60psi and when it gets to normal operating temp 35psi but if you get the rpm's high enough it will go up to 40psi
