6x9 Fitment on a 99 ram ext. cab
Old Dec 2, 2008 | 05:37 PM
sfs's Avatar
sfs
Ok I will pick up some washers before i start. Did the front of those speakers interere with the front of the door panel?
Also when you guys changed out your rear 5.25's did you remove the entire rear panel or just pull the front out and squeeze your arms in?
Old Dec 2, 2008 | 07:16 PM
sfs's Avatar
sfs
I know someone here has taken their panel off before to change these speakers? Help me here guys!!!
Old Dec 2, 2008 | 08:17 PM
95 Jamin Ram's Avatar
95 Jamin Ram
I have a 95 any my door panels do stick out a little bit but its not really noticeable and the door panels still go on fine. You may not need the washers kowboydmac said his went rite in something could have changed after my year.
Old Dec 2, 2008 | 08:30 PM
dhvaughan's Avatar
dhvaughan
here you go. i hope you like pics.
i installed rockford 6x9 with 1/4" spacers.
very slight, but acceptable bulge in door panel.
https://dodgeforum.com/forum/audio-v...-speakers.html
this link looks weird. testing.
Old Dec 2, 2008 | 10:45 PM
Laramie1997's Avatar
Laramie1997
Originally Posted by sfs
Laramie,
what is the model # of the infinitys you have in your truck and how much do they cost?
Ram,
What do you mean by spacers and where do you get them?
Ok this is close to what I have mine are Kappa Perfects
These are just Kappa
http://www.infinitysystems.com/car/p...=US&Region=USA
I would not worry about the difference between the two unless you are going to use an external amplifer ie. another amp besides direct connection to the head unit.
I caught my speakers on sale a bestbuy for $121.00 Reason for the low price is the fact that they fased out Kappa Perfect Multicomponet speakers
Old Dec 2, 2008 | 11:02 PM
sfs's Avatar
sfs
I think Im gonna give the pioneer tsa6962 or the tsa6972's a try, they have the mounting specs just one has a bigger tweeter.
I still need to find out if that entire rear panel needs to be removed or not on the ext. cab..
Thanks again...
Old Dec 3, 2008 | 02:57 AM
bigster's Avatar
bigster
Great stuff! I would suggest using a piece of plywood as a spacer instead of bolts, it seals the hole better and gives a better sound. When you buy speakers, there's usually a die that you can use to cut out the hole for the speaker, use that to make a spacer in plywood.
Greetz,
Bigster
Old Dec 3, 2008 | 03:15 AM
jasonw's Avatar
jasonw
Site Moderator
To install the rear speakers, you need to remove the rear panel. I removed everything except for the top 1/3 or so, and managed to squeeze the work in.
I have Infinity Reference 9623i speakers in the fronts and Infinity Reference 5022i speakers in the rear, and I like them just fine. If HTM had told me earlier that 6.5" speakers would fit in the rears, I would have bought those instead, but nooooooo...
J/K HTM.
Old Dec 3, 2008 | 07:49 AM
sfs's Avatar
sfs
Jason,
Did you remove the rear seat or just flipped it up and what about the seat belts?
Old Dec 3, 2008 | 05:42 PM
babyhuey6810's Avatar
babyhuey6810
Default I used jvc's from wally world
fit is great and sound is better than stock.No bulge in door panel.Cant remember part # but they were low buck specials.I used kenwood 5.25 in rear doors,but i cant hear them without cutting out fronts.I squeezed arm in to install .You also need new door clips.Buy the big pack at advance auto.They say ford on package{ugh},but they work like mopar.
