CB Install Image
#141
the clip they included didn't work well with my rearview (its made for the airhorn landyard on a tractor trailer rig)
i got a heavy zip tie, works great
i saw how you mounted your antennas, i wish i had a rack like that(that sounded wrong on so many levels), but see no need for one in my truck, or the money spent on it
#143
#145
Mine Cobra 29LTD:
Took that after I moved it down there..
Was installed on top of the dash, but rough driving created cracks around the screws and it broke loose.
I have the power wire wired into the radio ignition wire, the antenna and PA wires run under the dash and out the passenger door.
I have a 30 something inch magnet mount antenna on the roof from RadioShack. I get SWR of a tiny bit over 1 when dry, bit higher wet.
I'm looking for a better antenna because I live in mountains. Maybe an amp, too.
I have a PA speaker mounted behind the grill. My mic is suspended from the overhead console with a small bungee-easily detachable and movable.
Any suggestions on a new antenna?
#148
is the new antenna you have now adjustable?... i would try take frist or nee time
FireStik is good......... well this site has alot of cool stuff
http://www.cbradiostore.com/servlet/StoreFront
i a little time im changing to dual whips
this is cool to
http://www.cbradiostore.com/servlet/...dge-Ram/Detail
^^^^ so you can run it up by the hood
this is cool to
#150
