Backup light feed wire
Old Dec 6, 2008 | 10:36 AM
dhvaughan's Avatar
dhvaughan
well i'll be damn.
i need to get out more.
to answer the original question, the backup light circuit is wired up to the switch on the drivers side of the transmission, near the front, behind all the linkage. i think its called the neutral/reverse switch. i don't know where it goes from there. that's also the park/neutral switch, and the truck will only start when that circuit is closed. so you have 2 different circuits here in the same place. be careful if you mess up the neutral/park circuit your truck won't start.
so i guess he's wiring in a reverse camera to a dvd monitor, otherwise he'd want either the official park/neutral wire, or else just feed it a hot wire to fool it. well i guess i learned something but it sure was hard to figure out what was going on...
Old Dec 6, 2008 | 08:30 PM
Viper37's Avatar
Viper37
I'd feed it a hot wire regardless. That way I could use the backup camera while I drive. That would actually be very handy in the traffic I live in.
Old Dec 7, 2008 | 06:49 PM
theviper90210's Avatar
theviper90210
Hey guys sorry i havent been on since I posted, Yes i have already bypassed the security stuff for watching while driveing, but the main reason for this reverse wire is so the monitor knows to switch to the reverse camera when put in reverse, which is why i need the backup lamp feed wire. For driving with the camera on you just have to wire the camera 12v wire to a constant 12v source and it will stay on all the time (or add a switch to turn it off) but just wanted to know a easy location of the backup lamp feed wire. Thanks guys!
Old Dec 8, 2008 | 08:56 PM
theviper90210
To the top
