PCM Power Control Module Question
Old Jun 26, 2015 | 06:30 AM
dljones2351's Avatar
dljones2351
Default the reason u had that problem
There a voltage relay on your alternater and pcm if one goes out it screws every thing up but the reason it goes out on pcm that means when u replaced the alternater the battery was connected and fried voltage relay or from sound system or changing anything that goes to pcm . My bad on spelling just rember do any work on car take battery of. My pcm took out alternater ac and trans it sucks
Old Jun 26, 2015 | 08:41 AM
Moparite's Avatar
Moparite
There are no relays in the charging circuit. The two field leads go directly into the pcm to regulate voltage. A bad connection can fool the pcm to overcharge the battery.
