cat problems
Old Dec 9, 2008 | 05:01 AM
zman17's Avatar
zman17
Retired Moderator - RIP
You can also get a spark plug non fouler, 19mm thread I believe. Works for some.
Old Dec 9, 2008 | 10:15 AM
kd7188's Avatar
kd7188
how would that work the 02 measures the air to fuel ratio how would a spark plug help
Old Dec 9, 2008 | 05:16 PM
zman17's Avatar
zman17
It's a Non -Fouler not a spark plug. It's a tube with male threads on one end you screw into the exhaust and female on the other to screw the 02 sensor in. They can be had at almost any parts store for no more than 5 bucks. It moves the 02 sensor out of the direct flow and fools the 02 sensor so to speak. Only thing I'm not sure of, is whether or not you should drill the small hole that's in the male end of it out to a larger size. Maybe someone else will chime in about this topic.
Old Dec 9, 2008 | 07:27 PM
kd7188's Avatar
kd7188
i know what you mean but were in the exhaust is out of direct flow
Old Dec 9, 2008 | 07:29 PM
kd7188's Avatar
kd7188
does it create a space between the pipe and the o2 holding it farther away
Old Dec 10, 2008 | 05:03 AM
zman17's Avatar
zman17
You put it in the same spot where the 02 sensor came out of. And yes it just mounts it out farther so the end of it is not down in the pipe.
Old Dec 10, 2008 | 09:15 AM
dblj16380's Avatar
dblj16380
A "friend of mine" had his converter plugged up and he got someone to put a straight pipe in it. Eventhough there is an O2 sensor before and after the converter, there was no CEL. I don't know if this is just luck or if it was something with his 99 Ram
Old Dec 10, 2008 | 06:14 PM
ice01's Avatar
ice01
Hey Hammer Z71 Super moderator placed the exaxt information you need under Technical Information -DIY section. Check it out it will show you how to adjust the spark plug non foulers to place your O2 sensor out of the direct exhaust path. Alot cheaper than a simm.
