Tranmission slipping in 1-2 shift.
Old Dec 9, 2008 | 01:02 AM
akyne's Avatar
akyne
Default Tranmission slipping in 1-2 shift.
2001 1500 5.9L 4wd Automatic. When the trans shifts from first to second the second gear engagement is very delayed. When it shifts it feels like the whole thing gets thrown into neutral for a few seconds. It'll rev way up and then shift. It only happens in the 1-2 shift and it mostly does it when the truck is cold. It is not throwing any codes whatsoever. The fluid was changed a few months ago and is at a good level and colour. It otherwise shifts fine. It came with a big aux. transmission cooler from the factory and I had a transgo shift kit installed a couple years ago. Truck has 100,000 miles on it. Any suggestions?
Old Dec 9, 2008 | 05:57 AM
MonteC's Avatar
MonteC
Adjust the 1-2 band.
Old Dec 10, 2008 | 11:25 PM
theviper90210's Avatar
theviper90210
I fell like mine is the same, should I just re-adjust to the specs for the tranny or just tighten the adjuster screw alittle bit (also its the screw on the outside of the tranny right?) Thanks
Old Dec 11, 2008 | 07:04 AM
MonteC's Avatar
MonteC
adjust it to spec. Dont just tighten the screw.
Old Dec 11, 2008 | 05:32 PM
theviper90210
10-4 thanks MonteC
Old Jan 12, 2009 | 09:42 PM
theviper90210
That 1st to 2nd gear band is the adjust screw on the outside of the tranny right? not the one in the pan.
Old Jan 13, 2009 | 07:55 AM
dblj16380's Avatar
dblj16380
+1 Montec
I just rebuilt my trans last weekend (46RE of course) and (correct me if i'm wrong MonteC) but the rear band (inside the tranny) controls low/reverse. and the front band (outside the trans) controls the rest. If adjusting the front band doesn't help, then you may have bad solenoids? Just a guess on those. Otherwise it looks like you are either spendind a chunk of money to fix it or getting greasy and smelly (thanks good 'ol ATF+4) like I did and repairing it yourself.
Old Jan 13, 2009 | 08:16 AM
aim4squirrels's Avatar
aim4squirrels
if you like the smell of ATF, try a nose full of diff oil.
Old Jan 13, 2009 | 08:19 AM
dblj16380's Avatar
dblj16380
No thanks!
I can get a good look at a T-Bone by sticking my head up a bulls @$$, but I'd rather take the butchers word for it?
Old Jan 13, 2009 | 12:22 PM
MonteC's Avatar
MonteC
Yes. Should be a 19mm Nut and a torx bit for the screw, depending on the year. i think the earlier ones are a square nut.
