dodge ram transmissions
Old Dec 11, 2008 | 07:12 AM
  #31
MonteC's Avatar
MonteC
Originally Posted by dhvaughan
when mine goes out i'm going to ship it to you to rebuild. (i'm serious).
Originally Posted by dodgeram07
+1 me too, MonteC when mine goes i may just have to vacation to your state and drop the truck off and get a rent a car
Originally Posted by jmhai
What state do you live ... please say N.C. would be great to have a person to trust when it comes to service...
My inlaws live in Kannapolis. Im about three hours away from them in Summerville, SC.
Old Dec 11, 2008 | 07:22 AM
  #32
dhvaughan's Avatar
dhvaughan
aha. 4 hrs away. got it. i even have a cousin there. ga freshman receiver AJ Green is from there. yep, someday, i can drop the t off on my way to the beach and pick it up on the way back...
Old Dec 11, 2008 | 10:12 AM
  #33
Kyole's Avatar
Kyole
Originally Posted by MonteC
Better stick to speakers and radios there audio mechanic.
What audiomechanic posted above is BAD advice.
actually, if you get a truck with higher miles, and you, or the previous owners have no momory of ever getting the tranny serviced, it is better to leave it alone. fresh fluid can be thinner than thick old nasty fluid, causing clutch slippage in autos.
Old Dec 11, 2008 | 11:20 AM
  #34
audiomechanic's Avatar
audiomechanic
Which is exactly what happened to me and this experience is what prompted me to post what I did.
When I got my truck, it drove and shifted like a champ. I did what any new used vehicle owner would do when I got it home: I changed all the fluids. The tranny fluid was still red but it was very dark red with little black particles in it. I thought I was doing something good. After changing the fluid, not 10 miles later, the slipping started. 2 weeks later, I'm dropping 2400 for a rebuild. If I had left it alone, I'm sure it would still be going now without issues.
Old Dec 11, 2008 | 01:07 PM
  #35
MonteC's Avatar
MonteC
Nope. It has nothing to do with the viscosity of the fluid. Your explaination actually sounds quite silly. Transmission fluid is basically hydraulic fluid, they share many similarities. In transmission fluid there are additives and detergents, to keep moving parts clean and the valves free. If you get a transmission with over 100k on it and no one has ever serviced it then the old fluid has lost all of the detergents and additives, they are all used up. So now all your left with is old basically hydraulic fluid.
When you do a flush service on a high mileage unit you break loose the crap that has built up in every crack and crevis in the unit. This crap floats around and hangs valves or clogs up the cooler lines.
If you do a simple pan drop and filter change and just add in new fluid to replace what came out of the pan you will help the transmission.
Please stop perpetuating myths. I have never built a transmission that was serviced properly.
Old Dec 11, 2008 | 01:35 PM
  #36
Ram2K1's Avatar
Ram2K1
Talking
Geez what are you? A professional transmission technician??
Old Dec 11, 2008 | 02:07 PM
  #37
Rex-TheDOGG's Avatar
Rex-TheDOGG
MonteC, it would be great if you could post up a list of mods and best practices that would help the longevity of our 46RE's. I know my previous owner did a transmission flush service before, but going by what I'm reading here, I don't think I want to risk that again.
Old Dec 11, 2008 | 02:17 PM
  #38
Ram2K1's Avatar
Ram2K1
x2...excellent idea. This forum needs solid tranny advice more than anything.
Old Dec 11, 2008 | 03:21 PM
  #39
scatpack_69's Avatar
scatpack_69
EXACTLY!! I was hoping after 4 pages somebody would post this, otherwise I was gonna have to...I personally dont believe in doing flushes, because it WILL knock losse all the crap and thats when things go bad. Just drain the fluid, replace the filter, and replace the fluid.
May be different between gassers and diesels, but you should look into aftermarket torque cnvertors and maybe a valvebody if you do alot of towing. The factory convertor on diesels is one of the biggest reasons they go out.
And I have $7500 in mine...
Old Dec 11, 2008 | 03:49 PM
  #40
MonteC's Avatar
MonteC
No, but i did stay in a holiday inn express last night.
