Sticking valve
Old Dec 10, 2008 | 05:54 PM
Keegan's Avatar
Keegan
Default Sticking valve
So I replaced the rocker and pushrod on the bad cylinder... they work fine, but the valve is sticking. I get an occasional backfire here and there, and it runs rough.
I removed the valve cover again and sprayed the spring down with some diesel fuel conditioner in hopes it would penetrate through to the valve itself. I also used some wd-40 and PB Blaster.
Any other ideas, short of getting one of those motor-vac services done?
Old Dec 10, 2008 | 07:57 PM
TheForce55555's Avatar
TheForce55555
The valve could be slightly bent not allowing it to run through the motions
Have you overheated you truck lately?
Old Dec 10, 2008 | 10:19 PM
Keegan's Avatar
Keegan
Talking
No I haven't... but the motor is so gummed up I think the original owner was lacking an oil change or 2.... or ten haha.
Anyway... the wd 40 and PB Blaster/ fuel conditioner WORKED!!! I have triple the power in this truck now!! It runs so smoothly, accelerates like a bat out of hell, and I even had the truck sideways in second gear tonight!
