Brake/Third Light do not work
Old Dec 12, 2008 | 09:12 PM
ILLIFIED's Avatar
ILLIFIED
Default Brake/Third Light do not work
Good evening everyone,
I bought a used 1994 Ram 1500 the other day and just noticed the brake lights do not light up when I press the brakes. The two rear lights work when my lights are on, just not when I press the pedal. The third light does not work either.
Is this a simple problem like a fuse or a loose wire that I might be able to fix myself?
Thanks for your help!
Phil
Old Dec 12, 2008 | 09:47 PM
Jimmeh's Avatar
Jimmeh
Check the fuses. They are located on the drivers side of the dash. You should see the cover when you open the door.
I had a similar problem, and it turned out to be my fuse. Only difference was that my dash lights and tail lights didn't work.
Old Dec 12, 2008 | 11:03 PM
ILLIFIED's Avatar
ILLIFIED
I'm embarrassed to say it was a fuse. Thanks.
Old Dec 12, 2008 | 11:30 PM
Jimmeh's Avatar
Jimmeh
Don't be! I always got questions, and somebody is bound to have an answer. Just got to ask the right people.
