Its alive
Old Dec 12, 2008 | 09:33 PM
guitarking135's Avatar
guitarking135
Default Its alive
I finally got my truck up and going. I bought it not running for 1250 and have about 800 in it and it runs like a champ. Only problem I have no heat. The engine isn't getting hot is should be 210 but its only like 150 160 any Ideas? Thermostate? Is it possible that the previous owner put one that was to small in there cause it looks newer? Also my steering is really loose at higher speeds we think its the steering stabilizer link. Has any one changed one of those are they hard to do?
Old Dec 12, 2008 | 09:51 PM
Ram2K1's Avatar
Ram2K1
The previous owner may have put a 160 deg t-stat in there... Try replacing it with a new one. The steering in these trucks just sucks...right after I got mine I bought a Skyjacker heavy duty steering stabilizer...very easy to replace. They just run about $40 or so...
Old Dec 12, 2008 | 10:11 PM
dhvaughan's Avatar
dhvaughan
congrats.
replace t-stat. check it in a pot of hot water before installing. check temp with cooking thermometer.
find where the play is. make sure your box is tight. mine was loose as a goose and 5 minutes of adjustment make it like new, well, maybe not like new but much much better. i've never changed a stabilizer, but i don't think they really do all that much.
Old Dec 12, 2008 | 10:24 PM
Ram2K1's Avatar
Ram2K1
The only place I can really tell much of a difference is on the highway. Before, I was constantly sawing the wheel at those speeds, and now it feels much more stable. As for normal city driving, not much different at all.
Old Dec 12, 2008 | 10:34 PM
meanwhitemopar's Avatar
meanwhitemopar
well the steering i fiound i have a lose bolt on the shaft going into the steering box, just a socket and tighten her up. the steering stabalizer, not hard to do, just found instructions.
Old Dec 12, 2008 | 11:22 PM
guitarking135
is this what we are talking about just making sure and this replaces my sway bar? or something else?
http://cgi.ebay.com/ebaymotors/STEER...s#ht_992wt_926
Old Dec 12, 2008 | 11:26 PM
Ram2K1's Avatar
Ram2K1
Yes, that's it, but it replaces your factory steering stabilizer. Yours should be black and look just like that one. It's on the passenger side up front.
Old Dec 13, 2008 | 08:30 AM
guitarking135
ok do you think I would be able to get one of these from like napa or some where like that?
Old Dec 13, 2008 | 09:29 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Not a Rancho most likely, but they all do sell them. Monroe probably. I wouldn't buy any less than a Monroe.
Old Dec 13, 2008 | 09:40 AM
guitarking135
how much do you think one of those would run?
