Old Aug 6, 2015, 11:47 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
head light switch
Old Sep 22, 2009 | 09:06 PM
rockjoc1979's Avatar
rockjoc1979
Default light problem
I had my lights cut out sunday when i was going to go to work. i pulled out the **** to turn the lights on and just my roof marker lights and my front parking lights came on. i replaced the headlight switch with the new one from autozone that includes the new pigtail harness and still got no lights. today i changed the turn signal switch and still have no lights. if anyone would know where to download a free wiring diaghram pleas help me out.
Loren
Old Oct 15, 2009 | 02:38 AM
Twisted1's Avatar
Twisted1
Default Ummm... yeah...
Ok, so this is probably the oddest thing I've seen inquite a while. When I turn on my headlights, my driver's side is on highbeam while my right side is on low beam. When I switch the highbeams on, the left side goes to lowbeam and the right side to highbeam. The highbeam indicator stays on all the time, but brighter when highbeams are on. I don't want to assume anything and end up screwing things up worse, so I figured I just ask around to see if anyone else had had similar problems and know of a solution. If someone could help me, I'd really appreciate it. I'd love to be able to see when driving at night, I found that the cops tend to like that as well.
Old Oct 15, 2009 | 08:05 AM
Hugh's Avatar
Hugh
change the switch and switch plug-in its more then likely burn't to. They sale
both together at autozone.
Old Oct 15, 2009 | 08:16 AM
95RAM360's Avatar
95RAM360
i had an electrical problem ( and instead of one high beam one low beam) i had my reverse lights comming on when i hit my brake.
turned out to be two melted wires, and a bad ground. So check all the wiring with a tester, and test all the grounds, and feeds.
Old Jan 11, 2010 | 08:51 AM
Ziggy2112's Avatar
Ziggy2112
I am going through my second headlight switch in four months on my 97 Ram 1500.
Is there some sort of permanent fix for this?
Also, can I use the recall parts for the Ram 3500 on my 1500? and will my dealer even sell me the parts?
Old Jan 11, 2010 | 09:18 AM
halfamil's Avatar
halfamil
I'm on my 4th one since it was new.The 3rd one(Chinese junk parts%^$#) lasted about 2 weeks!!!
Old Jan 11, 2010 | 09:51 AM
imhotep's Avatar
imhotep
Originally Posted by jasonw
This is why I and several others have rerouted our headlights through relays, so there's no load on the switch itself, and our headlights/fog lights are slightly brighter as well because they are pulling power straight from the battery.
I am not much of an electrician, so is there a DIY on wiring your headlights/fog lights through relays? I have had no trouble in my 98 with the head light switch yet but I happen to believe in preventative maintenance.
Old Jan 11, 2010 | 09:57 AM
halfamil's Avatar
halfamil
My factory switch lasted over 250 K
Old Jan 11, 2010 | 10:57 AM
Flue's Avatar
Flue
Old Jan 11, 2010 | 12:24 PM
imhotep's Avatar
imhotep
Originally Posted by Flue
Thanks. This seems to also tell you how to wire in the sport heads lights not jsut te relays.
