Still pinging
Old Dec 15, 2008 | 12:05 AM
Mowhawk's Avatar
Mowhawk
Default Still pinging
Well, my 180 t-stat is installed and im still pinging under throttle.
Old Dec 15, 2008 | 12:29 AM
Ramman18's Avatar
Ramman18
yeah, that happened to me too. All the cooler stat is good for is a little more pep as my motor really fell flat on stock stat. Anyway, when I installed my hypertech, it pinged terribly until I switched back to champion plugs and ran plenty of seafoam and mccc through it. I also run 89 octane and hardly get a ping anymore. When I hear it, I know it's time for more seafoam.
Old Dec 15, 2008 | 12:34 AM
Mowhawk's Avatar
Mowhawk
i run 93, guess i need to switch to cooler plugs
Old Dec 15, 2008 | 07:32 AM
dhvaughan's Avatar
dhvaughan
i added a hypertech and mine started pinging really bad. 3923 didn't help. 89-93 quietened it down. turned out to be blown plenum. fixed that and now it runs 87 fine w/no ping. check for a big puddle of oil in the bottom of the plenum.
Old Dec 15, 2008 | 07:39 AM
BlueBeast2's Avatar
BlueBeast2
I hope after all my mods I don't have this problem. The engine will be clean. I'll have the cooler plugs and 180 t stat. I'm praying for a flawless no problem install
Old Dec 15, 2008 | 01:12 PM
pcfixerpro's Avatar
pcfixerpro
HA! lol... like thats gonna happen Jk, I hope so too.
Old Dec 15, 2008 | 01:16 PM
Ram2K1's Avatar
Ram2K1
I would think that with your plenum being 100% good after the build-up you shouldn't have any problems...I'll pray for you, too.
Old Dec 15, 2008 | 03:03 PM
BULLRAM's Avatar
BULLRAM
Did you check to make sure the intake is still sealed, did you use the felpro/victor gasket or did you get the Hughes Engines one, I have not had ANY hughes engine ones come bacK at all, but from what i have seen the stock Silicone fix, and sometimes the felpro/victor ones will re-leak. the hughes is a 1/4 inch thick plate that doesnt bend or distort, and it comes with a hard type gasket ,and bolts, that you loctite, just thought I would share incase someone has not heard of these............kind of pricey ,but for piece of mind........and also usually the converter is getting plugged up from all the oil,have the shop run a converter temp test.
http://www.hughesengines.com/partDet...698&eTypeID=10
Old Dec 15, 2008 | 10:32 PM
lastrights's Avatar
lastrights
yeah cooler plugs should work
Old Dec 16, 2008 | 03:25 AM
Mowhawk's Avatar
Mowhawk
nope my plenum is fine. I reinstalled the tune becaused it errored out the first time, so far im not pinging but i also added injector cleaner. Im most likely going to go the rout of cooler plugs though. Will keep updated.
