Door Hinge Pins
Old Dec 16, 2008 | 05:46 PM
lpd57's Avatar
lpd57
Default Door Hinge Pins
My 1995 Ram 1500s door pins and bushings need tobe replaced. I can't find a place that says they are avalible. Does anybody know why they aren't and any sergestions to replace them
Old Dec 16, 2008 | 07:51 PM
PurplDodge's Avatar
PurplDodge
I think LMC Truck has em
Old Dec 17, 2008 | 12:54 AM
olyelr's Avatar
olyelr
I don't know where to purchase the pins and bushings, but I do know it is easy to buy the whole assembly (pins/bushings/hinge) from a junkyard and bolt it on. I did it to my dads truck several years back. Just make sure the junkyard ones are good.
I have also just adjusted the whole assembly with the worn bushings/pins. Mine are kinda worn on my truck and I noticed it when the door started hitting the striker latch. All I did was loosen the bolts on the lower hinge (very slightly), lift the door up a smidgen to where it was lined up and closed properly, and then tightened the bolts back up. It has been working good for the last few years since I did it.
Old Dec 17, 2008 | 04:53 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Dorman makes pins too. They are in the HELP! section at the auto parts store.
Old Dec 17, 2008 | 08:44 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
LMC has a kit for one door. I've read threads here where people have replaced them and the feedback was that it's quick and easy.
