Dodge Ram 2500 2001 Transmission Shifting Problem
Old Dec 17, 2008 | 03:24 PM
guapoben's Avatar
guapoben
Default Dodge Ram 2500 2001 Transmission Shifting Problem
I own a 2500 model 2001, with 120,00 miles. I started having problems with transmission shifting, slipping first, then 3rd gear wouldn't go in, now even 2nd gear wouldn't go in. But If I shift to Neutral, rev it up a little and move back to D, then it would go into 2nd or 3rd gear. It didn't matter if it was cold or hot. Fluid level was ok, pretty red, no burnt smell, filter changed 6,000 miles ago,
I reviewed many posts in this forum, I had it checked with diagnostic computer and got a governor sensor malfunction code, as many of you suggested in simmilar cases. I'm having it changed. $150 bucks for the part and installation.
Thanks to the info found on this forum, I could talk intelligently enough with the mechanic to know what was going on. Thanks
Old Dec 17, 2008 | 03:30 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I did not contribute to the info you got here(about the tranny anyway), but I hope it works for you. This is a great site with a lot of great people, (just watch out for purpldodge) ! Sometimes he acts like he's 13 or 14! LOL JK
Old Dec 17, 2008 | 04:32 PM
MonteC's Avatar
MonteC
Change the governor sensor and solenoid at the same time.
Old Jan 2, 2010 | 06:42 PM
overs ram's Avatar
overs ram
so.. what was the result?
new years eve mine started doing same thing, I'm assuming It needs a rebuild or swap BUT if I can get away simple cheaper options great!
...stilll searching, this is my DD, low$avail.
Old Jun 26, 2017 | 03:14 AM
Dougroydog's Avatar
Dougroydog
Default How to adjust the bands on 2001 Dodge Ram 2500 4x4
How do I adjust the bands on a 47RE in a 2001 Dodge with a Cummings Deisel?
Old Jun 26, 2017 | 10:01 AM
Download the factory service manual for your truck from here. Procedure is in the trans section.
welcome to DF!
