ex mod help
Old Dec 17, 2008 | 09:04 PM
kd7188's Avatar
kd7188
Default ex mod help
so recently i gutted my cat and did the non fouler trick and ran my exhaugsht out the side but now i am thinking of getting headers cat and dual exaughst out the rear the only problem is there is no full set out there that i can find i want to order it all and simply bolt it on but if anyone could help with what connects to what or reccomend how they did it on their truck thanks for the help by the way the non fowler trick worked great
Old Dec 18, 2008 | 12:54 AM
firemedic0135's Avatar
firemedic0135
When I put true duals on my T/A I built my own.
Just put the headers on and go from there.
You can buy mandrel bent pieces and cut and weld them where you need them.
I would use one of those dual in dual out magnaflows that have the x-pipe inside to eliminate that step and then dump it.
Old Dec 18, 2008 | 01:39 AM
HammerZ71's Avatar
HammerZ71
Yeah, I did my own pretty much from my LT Headers on back, but I kept the stock cats, just moved them back about 18" because of the header length. I basically traced the shape of the route on sheets of cardboard and had a local shop do the bending. Used a short "Y" pipe that the local muffler shop stocked just before my si/do muffler.
If you can't weld, pick up a small, 110v mig welder. To an old stick welder like me, using a mig is almost like cheating. You can probably practice on scrap for a couple hours at most and be good enough to do your own exhaust...
Old Dec 19, 2008 | 09:54 PM
kd7188's Avatar
kd7188
thanks for the input can't weld but i can put on pipe clamps
