02 Wiring Question
Old Dec 19, 2008 | 12:03 PM
chet's Avatar
chet
Default 02 Wiring Question
I think i have either A) Fried a wire going to the O2 sensor B)Fried whatever is that the other end I.e Fuse ?
Heres the story, i was hooking up my A/F gauge and was completly backwards and was trying to hook it up on the front sensor. Anyways two wires touched sparks flew and now my check engine light wont go off for the voltage being to high. I have replaced both sensors since then and it still does it, also sometimes my back one comes on with the heating element not working on both but then goes off after awhile so where is the control module thingy to turn the heating on ?
My question is where does the wiring harness go, is there a fuse ? How could i check for a fried wire ? What else could be wrong ?
Old Dec 19, 2008 | 12:14 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Look for fuses in the PDC under the hood. Hopefully that's it. That's why you disconnect the battery when doing electrical. BTW, check all the fuses and relays, even the ones by the driver door.
Old Dec 19, 2008 | 03:22 PM
chet's Avatar
chet
k. the fuse was blown now to hook the gauge back up. If i could only remember where to hook it, someone once said by the fuse panel but i dont know which wire.
Old Dec 19, 2008 | 04:19 PM
zman17's Avatar
zman17
OK! Now drive it around and run it to make sure everything is OK first. Then find the directions for the meter and hook it up correctly.
