4x4 problem need help
Old Dec 27, 2008 | 02:39 PM
Cartalk2's Avatar
Cartalk2
Zman17 -- The black composite bushing you speak of, is this the one in the shifting fork inside the Tcase? I'm currently going thru a little different problem as mine will not shift into High 4WD, but as I continue will go into low 4WD. In both cases the dash light is on and shift lever seems to move normal.
Old Dec 27, 2008 | 05:32 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The bushing is in the end of the outer shaft where it connects to the inner shaft. Its hard to see, you'll just see the thin lip of it in between the 2 shafts.
Old Jan 8, 2009 | 11:05 PM
wingnut71's Avatar
wingnut71
Default cad unit
hi all newbie here i got a question here its goes when i drive my 99 ram on the road at 55 mph my 4wd seems to disengage then re- engage what could be wrong it doesnt do it right away either i have to be driving for like 15 miles before it starts doing that but its disengages re-engages 20 30 seconds later does it again repeatedly until i take it out of 4wd need some help here thanks
Old Jan 9, 2009 | 06:30 AM
zman17's Avatar
zman17
You got to do the same thing as previously stated. Check all the vacuum hoses . Including the ones coming from the engine. There is also a vacuum switch on the transfer case that can be removed and cleaned. Just follow the hoses form the axle and you will see it.
Old Jan 9, 2009 | 01:34 PM
98BlackRam's Avatar
98BlackRam
so i figured out the grinding was because of the snap ring broke on the rear output shaft of the transfer case. I put a standard snap ring in and ordered a transfer case saver piece, the 4wd worked with the standard snap ring then i put the transfer case saver in and now it wont engage.
Old Jan 10, 2009 | 10:37 AM
98BlackRam's Avatar
98BlackRam
now its going into 4wdHI and the light is flickering off and on
Old Jan 10, 2009 | 11:29 AM
zman17's Avatar
zman17
That maybe just a bad connection at the switch on the CAD or the switch is no good. So the grinding is gone and it's fully engaging to 4hi ?
Old Jan 10, 2009 | 06:56 PM
JBs DAK's Avatar
JBs DAK
I was told by my Trans-Mechanic the Snap/Ring does
break quite often and that Mopar had a up-grade for this problem.
