O2 sensor
Old Dec 21, 2008 | 08:00 PM
WaynesWorld's Avatar
WaynesWorld
Default O2 sensor
Is there a preferred brand / manufacture make of O2 sensors for our Trucks? I tried searching, but the search function omitted the word O2
NGK?
Bosch?
Mopar?
eBay?
Old Dec 21, 2008 | 09:02 PM
aim4squirrels's Avatar
aim4squirrels
the NTK (made by NGK) O2 sensors are the OEM replacements and better than the Bosch ones IMHO.
Old Dec 21, 2008 | 09:58 PM
WaynesWorld
thanks. Is the correct one for the cat converter NTK PN#23099?
Old Dec 21, 2008 | 10:05 PM
WaynesWorld
man why is it so confusing......
I want to replace the o2 sensore in the cat, but when I look up it list before cat or after
Old Dec 21, 2008 | 10:06 PM
aim4squirrels
It could vary by model year and pre vs. post cat. Or do you have the type that is straight into the middle of the cat?
Try looking up your part by vehicle selection at napaonline.com They give you pics and if you see NTK or NGK in the part description then that's the one you want.
Old Dec 21, 2008 | 10:26 PM
WaynesWorld
yea, I got the one that goes straight into the cat. I am replacing the cat and might as well replace the o2 sensor in it while I'm at it.
..... but, napa, autozone, NGK all list before or after cat
Old Dec 22, 2008 | 01:48 AM
jasonw's Avatar
jasonw
Site Moderator
The one "in" the cat is the same as "before" the cat, I believe. (At least, in parts descriptions anyway.)
Most later models (1999-up, maybe some 1998s as well) had a y-pipe going into a converter with the sensor before the y-pipe, rather than one in the converter.
Old Dec 22, 2008 | 03:56 PM
WaynesWorld
For the record.......
I went to the dealer today and asked about the sensor. It is called the downstream sensor.
Old Dec 22, 2008 | 06:48 PM
zman17's Avatar
zman17
Retired Moderator - RIP
If it is before the cat or in the cat it is the UPSTREAM! After the cat is DOWNSTREAM.
