Pinion Bearing Probs
Old Dec 22, 2008 | 01:57 AM
Thumpper369's Avatar
Thumpper369
Default Pinion Bearing Probs
I thought u had to replace the pinion bearings... i finally bought the tool for the adjuster and had to make a tool to hold the flange. well when I went to loosen the flange nut on the pinion it was finger loose i could turn it with my fingers... so i figured my bearings were still ok i got a new crush sleeve put everything back together and tightened the nut as tight as I could get it and I still have play in the flange i can move it left right up and down. i took it back apart and i noticed the crush sleeve didnt crush i reafed on it til I couldnt move it at all anymore does any have any suggestions?
Old Dec 22, 2008 | 01:59 AM
Thumpper369
forgot its 2001 Dodge Ram 1500 4x4 5.2L 9 1/4" rearend with 3.55 gear ratio
