Fluid Change Time
Old Dec 23, 2008 | 11:39 PM
chet's Avatar
chet
Default Fluid Change Time
Im getting ready to change my fluids i think im going with Amsoil and have a few questions. i got my trans rebuilt a little over 10k miles ago and i want to change the fluid/filter is amsoils ATF fluid good enough to be ATF+4 or not ?, also any other suggestions that i should look at/do after a rebuild ? Im also going to be seeing if i cant find someone to weld a nut in so i can put a drain plug, is there some sort of kit or just a random nut/bolt work ?
Also i want to change the oil in the Front/Read Diff do i have the dana 44 or 60 ?
Transfer case where can i find my model ?
And if anyone has any pointers on how to replace the fluids in the differentials or transfer case it would be much appreciated.
Old Dec 23, 2008 | 11:55 PM
PurplDodge's Avatar
PurplDodge
Front dif is a Dana 44
Rear is a Chrysler 9.25
Old Dec 24, 2008 | 12:24 AM
vmann's Avatar
vmann
use royal purple. expensive but high quality.
Old Dec 24, 2008 | 12:26 AM
dodgeram07's Avatar
dodgeram07
for the trans stick with ATF+4..
but thats me
Old Dec 24, 2008 | 12:31 AM
vmann's Avatar
vmann
i dont run royal purple because i cant afford it. but if i could i would =]
Old Dec 24, 2008 | 01:47 AM
minis2003's Avatar
minis2003
both royal purple and amsoil are great products for fluid and will out last stock oils.
http://www.royalpurple.com/rp-videos.html some good reason on why you want Synthetic
Old Dec 24, 2008 | 02:40 AM
JackJ's Avatar
JackJ
I use Lucas oil in the diffs on my truck and my JEEP and in the Xfer case in my JEEP. As for oil in the truck, I use what ever I can afford at the time, but I change that so often I really dont care, the JEEP I use high Milage oil mainly because it is a 30 year old motor.
