Transmission identification
Old Nov 4, 2017 | 01:34 AM
  #71
snakeeyesracing's Avatar
snakeeyesracing
Here's a question seeing as this is back up, is the V10 47RE the same case as a Cummins 47RE? I have this taboo plan if/when mine gives up. It's already used on the Cummins engines and if the case bolts are the same it should smooth things out if I do it.
Old Nov 4, 2017 | 09:55 AM
  #72
8.0 and the diesel use the same bolt pattern. Don't know if the torque converter is the same pattern though......
Old Nov 7, 2017 | 11:42 PM
  #73
snakeeyesracing
Thank you
Old Nov 11, 2017 | 06:36 PM
  #74
WilddodgeramBill's Avatar
WilddodgeramBill
Ok I have a 1996 dodge ram 1500 5.2 2wd.....bad trans bought one at a pull-a-part out a 97 5.2 2wd and it's not the same looks same but my torque converter won't fit ...mine is small shaft ...if I get torque converter will this trans work or do I have to find a hole nother trans can someone tell me what trans I have
Old Nov 11, 2017 | 06:46 PM
  #75
Should be the same trans.... unless one or the other was swapped out at one point. Probably wouldn't hurt to get a build sheet for your truck, to see what the factory sent it out with.
Also, you don't want to put the t/c from a bad trans onto a good trans, as it is impossible to actually clean out the old one, without cutting it apart. Did the 'new' trans not come with a t/c?
Old Dec 22, 2017 | 12:35 AM
  #76
Joe Jordan's Avatar
Joe Jordan
Thought C4 was an explosive?
C4 is a Ford transmission for small block engines.
Old Jul 22, 2018 | 10:43 PM
  #77
eternaltru's Avatar
eternaltru
Default Transmission only
I have no info on the transmission other than the stamped number above the pan. PK 52119822 AA 3028 1523
so if the middle number is suppose to be the build date, somebody traveled back. Everything looks the same as my 518. Except the nuetral sensor. It is round on the purchased tranny and the 518 has the 5 wire square sensor.
Story is i bought a tranny that is said to be a 46re to replace the one in my 03 durango 5.9l 2wd. Not sure if it’s compatible as even dodge didn’t have an answer for me. He said I can bring the tranny back and he will change out the sensor to match my durango. I dont know if it’s possible or not. But I would like to know what tranny it is so if I need parts I get the correct ones. Thanks
Old Jul 23, 2018 | 07:56 AM
  #78
Things changed over the years..... take it back, and see what he can do.
Old Jul 23, 2018 | 04:10 PM
  #79
eternaltru's Avatar
eternaltru
I dropped it off this morning. He said the switch is interchangeable. We’ll see. I also noticed that the pan on the bought tranny has a step in the corner as where mine does not. Not sure if that means anything but I’ll see what happens when he calls me back. Appreciate it!
Old Jun 6, 2019 | 06:15 PM
  #80
Tundra's Avatar
Tundra
it is when you hit reverse while you are doing 95 MPH... this i know from experience LMAO.. 8D
