Dash replacement
Old Dec 25, 2008 | 10:00 PM
RockinKgin's Avatar
RockinKgin
Default Dash replacement
The dashboard on my '96 2500 CTD 4x4 in cracking badly. How do I remove and replace it?
Old Dec 26, 2008 | 01:41 AM
Cummins12Valve's Avatar
Cummins12Valve
Ive heard alot about this, the easiest cure is a dash plate which is just a replacement for the top of the dash, heard its a lifesaver.... apparently its a Big job doing a swap
good luck
Old Dec 26, 2008 | 01:51 PM
Gav1n8's Avatar
Gav1n8
It is a big job doing a swap and very costly if you have a profession do it. Took me over 8 hours of wrench time before I finally got mine swapped... Biggest waist of my life... Take my advice and just buy a carpet cover for it. or do the above...
Old Dec 26, 2008 | 02:27 PM
Kindschi's Avatar
Kindschi
Buy the carpet cover for the top. It can take several hours to swap them and its really not worth the time. IMO
Old Dec 26, 2008 | 04:17 PM
CaptCameltoe's Avatar
CaptCameltoe
I can do a 94-97 dash swap in 2 hours, it's really not that big of a deal. First time I did it I went really slow and still had it done under 5 hours.
Old Dec 26, 2008 | 09:56 PM
Gav1n8's Avatar
Gav1n8
Were not all master mechanics like you bud... 8 hours was a exageration.
Old Dec 26, 2008 | 10:47 PM
dodgeboy7's Avatar
dodgeboy7
I just got done doing mine about mouth ago it easly just take some time the biggest pan is the streeting clom eletirc plugs are by the wheel you have the take the plastic off around the clom like were the turn sign swich is. Did mine Fri night and sat afternoon lots of breaks and doing others stuff.
Old Dec 30, 2008 | 07:12 PM
ramsportguy's Avatar
ramsportguy
I had my a/c serviced and before i had that done i bought a OEM dashpad .Costed me 364.00 for a new one.While they were doing the a/c i had them swap the dash pad out.I bought a dash carpet right after that since i dont plan on replacing that dash piece again.
thanks
pat
Old Dec 30, 2008 | 08:26 PM
Ram2K1's Avatar
Ram2K1
Check these out:
http://www.lmctruck.com/ICATALOG/DE/full.aspx?Page=77
Best bet if you ask me...
Old Nov 2, 2009 | 05:33 PM
slyster's Avatar
slyster
Default Any tips for replacement?
I pulled a dash to replace the cracked one in my 95. I haven't put it in yet because I was dreading the amount of time it was going to take. So you're giving me a thread of hope. Any tips on how to do this...or anything in general. The only help I'll have is from my 7 and 9 year old boys.
Thanks, Sheryl
