1999 dodge motor transplant
Old Dec 27, 2008 | 02:58 PM
modracer's Avatar
modracer
Default 1999 dodge motor transplant
hey everyone
i have a 1999 dodge ram 1500 2wd and in the summer i blew the engine out of it. it was a bunch of things that went wrong with it first the # 8 injector failed open witch dumped raw full into the cat and plugged it with over heated the valves and i lost compresion. i have found a 318 out of a 1995 dodge ram 1500 4x4 with 180 000km on it for $500.00 so i was wondering it everything is compatible wiring, headers and transmition
thanks kyle.m
Old Dec 27, 2008 | 04:04 PM
JimkDaAdtman's Avatar
JimkDaAdtman
is yours a 318 now? if so, then yes, it should go together nicely.. no issues at all. If it's not a 318 in there now, then you need to change the computer, because the computer is set up for your motor you have now.. Computers are available easily on Ebay, and the likes, and aren't that costly anymore.. So, either way it should be no problem..
Old Dec 27, 2008 | 04:23 PM
rabbler's Avatar
rabbler
Are you just swapping the engine?
The basic block is the same but you will need to swap over lots of components from your blown 99 engine to the "new" 95 engine.
Off the top of my head, Intake manifold, exhaust manifolds, all sensors, injectors, distributor, flex plate.
The connectors and wiring are substantially different from 95 to 99.
Old Dec 27, 2008 | 04:47 PM
modracer's Avatar
modracer
allright thanks guys..ya its a 318 in it now so i gess i get to work and hopefully i have it back on the road soon
Old Dec 27, 2008 | 07:22 PM
dhvaughan's Avatar
dhvaughan
post pictures. we like pics. they entertain us.
just fyi, the reason you are swapping over so many parts is that the 95 is OBD I and your 99 is OBD II. so the sensors, computers, etc are all completely different.
